Multi-body print question 1
heythere
Aerospace
Dec 27, 2016
15
I know I'm doing this wrong, can someone point me in the right direction? I'm making a blueprint for a fixture with three separate pieces that fit together. The first page should show all three. The second page I just want one of the pieces. Currently I suppress the body I dont want to see, so it doesn't show up but that of course makes it disapear from sheeet 1. Do I turn off auto update? Seems like there is an easier way. Is there a way when I create a Base View to only display one of the three connected bodies?
It sounds like all the bodies are in the same files as the drawing?
If that's the case, use 'Layer Visible in View' to control the layers shown in the drafting views.
The attached video explains how to do it.
Anthony Galante
Senior Support Engineer
NX3 to NX11 with almost every MR (24versions)
If you've set it up as an assembly you can also hide/show specific components on a per view basis. Use command finder for "hide show component in view".
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Enterprise x64 SP1
Intel Core i7 2.5GHz 16GB RAM
4GB NVIDIA Quadro K3100M
