STpipe
- Apr 29, 2010
- 161
This might come off as a bit of a rant, but I'm wondering if there is a good guide on how to properly setup the automatically generated load combinations for steel design based on the National Building Code of Canada?
The first frustration I found was in setting up the notional load. You can easily setup the auto feature and assign it to the Dead load pattern, however somehow snow is not part of the dropdown option? I found a workaround where if the snow load is defined as a "roof live load", then that load pattern can be chosen to automatically generate the notional loads. When defining the load combinations however, you then need to re-assign it as a Snow load or else it won't generate any load combinations with snow because there is no such thing as a roof live load in NBCC unlike ASCE 7.
Next, it generates the pure gravity loads, alternating the notional loads correctly with the right load factors - great. But then when it comes to the other load combinations where you have wind either as a primary load, or as a companion load, the notional load is not included. So am I missing something here, or do you need to go in and manually add them afterwards?
