NC 9V LED circuit 2
banderas
7
I tried to build a simple LED circuit that is going to operate from 9V battery. When NC switch is closed I wouldn't want to draw any current, but this NC switch opens turns on red LED. Circuit I build was heating up the battery. My only requirements are low power consumption (so battery can last long time), fewer components-better.
Any suggestions?
Thanks in advance.
Banderas
Excuse me banderas. Are you serious? Or is this a fun thing?
You have identified yourself as banderas(Electrical) and that has to have some ground. One is that you have learned to connect a battery and a switch and a load in series - not parallel. Have a look at your circuit. And, BTW, do not forget a current limiting resistor in series with the LED.
skogsgurra,
Sorry if my question irritated you,but I tried to build something really simple to indicate when NC switch opens.And I got stuck.I tried pasting my circuit to forum the but it didn't work.I know how to to this with the logic gates but I don't have power available.Thanks for your reply.
Banderas[peace]
banderas,
I did not mean to be mean ;-)
But sometimes people try to be funny. I thought that you were. Sorry if that made you feel bad. Does it work now?
You could add a npn transistor. Put the base and emitter accross the NC switch. Collector goes to 1500 ohm resistor, LED and then +9V bat. Negative goes to transistor emitter. This will give you 5 ma which won't be real bright. If the transistor has a gain of 100, you will need base current of 0.05 ma or 180K from base to bat positive. This will waste some current but not much. Get a transistor with twice as much gain and you can reduce the collector resistor to 750 ohms and 10 ma through the lamp.
Thanks for your help OperaHouse. This worked. I'll play with resistor values to get brighter LED.
Banderas[2thumbsup]
I would have thought a 2 position switch would work pretty well here, the load to one position and the LED to the other....
