Hi all,
I'm a long time reader, but post very infrequently. Looking for a little advice. I recently purchased a 2012 Acura TSX Sport Wagon...currently ~70 miles on the car.
I have questions about break in technique and duration as well as engine oils and change intervals. The engine is a 2.4L I4 i-Vtec.
What is the proper engine break-in technique on modern engines? With 70 miles already on the car, is it safe to say that the rings have already seated? Is there any point to additiona periods of high-gear, high-load operation to continue to seat rings? Should I make efforts to vary RPM throughout range? Should I limit max RPM for any period of time? Any input on this topic would be appreciated.
Owner's Manual calls for 0W-20 oil that's API approved. Am I to assume that the oil in the car now is synthetic if it's a 0W-20? I'm not aware of 0W conventional oils?
OCI's are 10K miles as per the on-board computer. This seems extraordinarily long, especially for the first oil change. (Makes me think it's got to be synth oil) What are your thoughts on an early oil change once "break-in" is complete?
Thanks in advance!
Thanks in advance!
