fracture_point
- Mar 7, 2019
- 58
In the design of a non-sway column, is it necessary to perform a p-delta analysis if you are using the moment magnification method if the column is slender (as per ACI)? Or is the moment magnification a method used in lieu of having to do p-delta?
If the latter is true, if we have a stocky column where it is below the limit for a slender column, is it necessary to perform p-delta at all?
