we are using NX 7.5 and it's Sheet Metal module gets heavy use during the current project. As the project has gone onwards, some weird behaviour (bugs?) has come up. Particularly Contour Flanges and Three Bend Corner features tend to cause problems. Sometimes when you do a Contour Flange, it stops working properly even after many features have been created later on after it. I start getting the 'Unable to create body' error - which did not appear the first time you created the feature. Also sometimes the Contour Flange creates overlapping geometry (ie. it won't miter some edges properly) which will not flatten.
We do have newer version of NX available, so if this behaviour is a known bug in 7.5 I can simply request an update. If not - are there certain workarounds or ways of working to avoid these error situations?
