dennisbruce
- Oct 14, 2013
- 16
While performing many modeling moves, such as copying a block using point to point move, or performing a split block, the result is an association between the two objects. So If I move either of the blocks the other comes along for the ride. The work around has been to remove the parameters from the blocks after creation. It is very annoying that they wouldn't provide a way to turn this automatic association off. Pretty short sighted if you ask me.
I had asked Siemens if they could at least give the option of turning of the automatic association for future releases. I just installed Nx11 (per GM dictate) and the association is still there and I can't find where I can turn it off.
