Hello All,
I've tried searching for the following topics, but haven't found anything, so if I repeat a previously posted question, please forgive and point me in the right direction.
My questions are:
Now that we can add/remove an all around symbol from annotation leaders, can we add/remove them from radial dimensions? How? If it's not automated, what's the best method for doing this?
Also, we have long been able to wrap a box around portions of text by using the "<&70><+>xxxx<+><&90>" control codes...is there a control code for wrapping a hexagon around portions of text? Are these control codes documented anywhere?
And finally... in the ID symbol dialog box when you choose the 'show shortcut' option in the type pulldown, only a few of the selections are available as buttons. Is there a way to change the options that show as icons. We use a lot of hex and rounded box symbols on our drawings, but those two don't show up as shortcut buttons by default.
Any help on any of the above questions would be greatly appreciated!
-Peg NX5.0.5.3 soon to be NX6.0.3.6
My questions are:
