OHGW - overhead ground wire on a tr
cesarcesar
OHGW - overhead ground wire on a transmission tower: want to ask if this GROUND conductor (which is installed at the highest position of the transmission tower) should be a BARE conductor or JACKETED conductor.... I thought : IN CASE OF LIGHTNING STRIKE, the bare conductor completes the circuit to GROUND. thank you.
You have reasoned it out correctly; jacketed would be a pointless waste of money and defeat the purpose of readily conducting lightning strikes to ground.
CR
For lightning protection with shield wire utility use bare OHSW or OPGW (Optical Grownd
Wire)
I thought the use of 5/8" steel was what is typically used?
Thank you. - use Alumoweld-Aluminum-Clad-Steel-Overhead-Ground-Wire for overhead shield wires.
