one side of a sheet body transparent 1
TCMartist
Marine/Ocean
Jun 20, 2006
21
0
0
FR
does anyone knows how to sort my prob:
I installed NX4 on a new machine and since, all sheet bodies, when object display is set with 0% transluency, come with one face invisible. I guess I must have a setting wrong and played with the visualization preferences but couln't manage to find a solution.
note that when I set transluency to 1%, the invisible side reappears...
thanks!!
Shade your model, then open the Visualization Preferences dialog (Preferences -> Visualization) and under the Visual tab, make sure Two-Sided Light is checked and see if that helps any.
Tim Flater
Senior Designer
Enkei America, Inc.
As long as it hasn't changed since NX2, try going to Preferences-->Visualization Performance and under the General Settings tab, make sure Backface Culling is UNCHECKED. I tried checking it and got the same results on sheet bodies as you are getting.
Good Luck!
.mark.
