Open the Part file through batch
SelvarajC
New member
Nov 27, 2014
26
Hi All,
Is there any option to open the part file through batch using command line argument.
Generally applications accepts the command line arguments. I tried in NX but it is not working.
For example:
call %UGII_ROOT_DIR%\ugraf.exe D:\files\testPart.prt
Thanks,
Selvaraj C
NX Automation Engineer
Selvaraj,
Add the -retrieve option to pass the part file name to ugraf.exe.
Code:
call "%UGII_ROOT_DIR%\ugraf.exe" -retrieve:"D:\files\testPart.prt"
Using ugraf will cause a new instance on NX for each "Call".
Using just the part name will cause windows to use the default association for the .prt extension (ugs_router.exe) which will start NX if needed or reuse a running instance and pass the part file to NX.
Code:
Call "D:\files\testPart.prt"
HTH, Joe
Thank you for your reply.
Where can I get these knid of batch arguments script info?.
Is anything mentioned in Documentation?
Thanks,
Selvaraj C
NX Automation Engineer.
Selvaraj C,
The NX launch command line switches:
[URL unfurl="true"]https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help/#uid:launch_win_switches_r[/url]
"Home -> Fundamentals -> Launching NX -> Start NX on Windows Platform"
Ugs_router.exe switches:
[URL unfurl="true"]https://docs.plm.automation.siemens.com/tdoc/nx/10/nx_help/#uid:xid280878[/url]
"Home -> System administration - Command line utilities -> Start and connect to applications"
Also, using an NX command shell and entering the command ugs_router with no arguments will cause a popup dialog that describes all of the arguments / options.
HTH,
Joe
