Ordinate Dimension - Snap points unavailable
MFDO
217
While in ordinate dimensioning, Snapping point options of Tangent point and Quadrant point are unavailable.
Why is it? How could I dimension to the nose edge with ordinate dimension scheme?
Michael Fernando (CSWE)
Tool and Die Designer
Siemens NX V9.0 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
If you're using the 'Type' option 'Single Dimension', than at least the 'Tangent Point' Snap Point is available. And before you ask why it's not available when applying 'Multiple Dimensions', try and imagine what TWO (generally at right-angles to each other) dimensions from the SAME 'Tangent Point' would even look like. I can't.
As for the 'Quadrant Point' Snap Point, I'm not really sure how much you'd gain by even having it. However, if you can show a good example of where that would be useful, please feel free to do so.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I hope this will be good example.
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
I would simply use the 'Type' option of 'Single Dimension' using the Snap Point 'Tangent Point' TWICE, or am I missing something? I could only see two possible uses of a 'Quadrant Point' and in both cases it appears that the 'Tangent Point' would have done the job.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Sorry John, I didn't clearly understand your first answer. ( I was in the view that you adding a separate dimension)
Having said that, while dimensioning under TYPE= Multiple Dimensions, I could select one dimension vector (i.e. under BASELINE). Hypothetically at this point I need to have the tangent point selection available. This is what I was missing.
Hmm... You are say saying instead of the above (changing the Baseline vector) I should go and change the Type to Single. I'll try it next time. Thanks again.
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
I could add another point to this topic.
We need “Tangent snap points” selection, when setting the margins too.
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
