Mohammad Saad
Hi, hope you all are doing well.
In the refinery that I work in, we have an Amine Regenerator unit that strips out H2S from Rich Amine (DEA). The top 3 shell courses are of SA-516 with SS304 cladding. We are having a leakage at the 4th shell course whose thickness was reduced from 16mm to a range of 7~10mm, and small patch where the thickness was around 3mm about 7 months ago. Belzona 1251 and FRP was applied but there is a leakage now. The exact position cannot be determined for now because of the belzona and FRP. The management has decided to reduce the pressure to zero and weld a patch plate over the entire effected area.
My question is, if this happens, how much chances are there for amine stress cracking or H2S cracking considering we have to keep the unit running for 2 months only (we have a complete Turn Around then, the entire shell course is planned to be changed in the TA). We are short on time so we cannot flush the vessel before welding. We are trying to study if the cracking would be a critical problem or not for the next 2 months.
