Pipe measurements
Lepetit
27
Hello all,
I want to monitored (mass flow and pressure) a pipeline of 6mm inner diameter and 8 mm outer diameter. does anyone know a company which sells components for these sizes of pipes?
Thank you very much
Siemens FC300 coriolis mass flow meter has a 4mm ID, so if you can take some pressure drop, it might work for you.
Catalog sheet here (Scroll down):
Basic specs:
Thank you very much both!!
I will check all the info. hank you again!
Cheers
