Hello everyone.
I have a question for pipe network analysis. This can be done by computer programs but I would like to know if there is a hand calculation (spreadsheet) method available.
Even if someone can point me to a reference book, I would be greatful.
I tried searching for this on internet but was unsuccessful.
My question is.
1. If we have a pipe network, how do we find the total head developed so that the pump can be selected.
2. If we have heat exchangers in parallel, how do we find out the pressure drop in each line (is it similar to electrical resistance in parallel) and afterwards the total head developed for the pump calculation.
3. If a pump is pumping to a single pipe which then splits in to two lines going to two tanks (open to atmosphere) how do we know what will be the flow rate in each tank if these lines dont have a flow control valve. How can we find out the total head developed by the pump. To make this question interesting what if the pipe size going to these tanks are different and that the fittings are also different for both the pipes and that the tanks are at different elevations.
4. For a cooling tower there are several discharge points for a single line, how do we find out the pressure drop and the flow rate in each outlet if these outlets dont have a flow control valve or even a butterfly valve.
Till date I was using Crane technical paper 410 to do the calculations for pressure drop, but that was for a single input and single output pipe with just one pump connected. there were cases of 2 x 100% pumps, but I simplified the calculation by neglecting one pump. I took the additional tee in the calculation for pressure drop.
The reason for asking all these questions is that they were in my head for a long time and now that client has asked us to perform similar calculation, I thought it is the best time to ask other questions too.
Dharmit
My question is.
Dharmit
