Mbrooke
- Nov 12, 2012
- 2,546
Is any one aware of, or sees an advantage in placing PTs within breaker bays (between the circuit breaker and disconnect) instead of on the outgoing line positions?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hi Mbrooke, no, I can't recall ever seeing my utility having any type of PT/VT between a breaker and its disconnects.
"Our" PT's are generally connected to the line/station entry bus-work by means of individual "pigtails" that can be readily removed/installed with a live line tool. This can be handy if one goes bad, since the line can often be returned to service with just two out of three PT/VT's functional, provided Protection and Control personnel make any necessary adjustments.
Any particular reason for placing them at the entry?
crshears said:Answer: I'm not privy to the reasons why those a lot further up the food chain do what they do, but almost all of our stations are breaker-and-a half schemes with disconnects on either side of each breaker. For line protection VTs/PTs it's about a 50/50 split as to whether these are connected to either the line itself or the T-shaped line terminal bus on the station side of the line disconnect switch.
Main point being that because pot sources are not located inside breaker disconnects, line protections can remain fully in service without modifications required if one of the two breakers is out of service for maintenance. Touching on something from another thread, if the line is two-ended and the entire terminal meaning "outside breaker disconnects by line disconnect" ] is out of service, the Zone 2 relaying at the remote end is typically made instantaneous to preclude timed clearance of line faults.
Edit/addition: I have NEVER seen CT wiring equipped with blocking switches; in my utility, across the board, links are used, with the rigid practice used of ALWAYS applying shorting links first before opening the CT circuit splitting links. Presumably there is an expectation of less human errors being made using this approach, although I couldn't say for sure that's why...
CR
