Plate with thickness variation
Me09
34
Hi Guys,
I want to model a plate with thickness variation. the nominal thickness is 2 mm but after measurement found the thickness is vary from 1.85 to 2.15 mm. My question is how I can model the plate? if I make the plate as a part with nominal thickness how I can apply the thickness variation?
so if we have a plate and thickness is not regular how we can define the dimension? how we can define the thickness 2 ± 0.15 mm?
Thanks Rob,
the problem is about modelling of a cantilever which is a part of machine. the machine sensitive to the frequency of the cantilever and I have found that the thickness of the cantilever is not the same. I only can measure the cantilever thickness from the edges and can not measure it in 3D to model exact shape. I want to model the cantilever when the thickness is not curtained. Do you think it is possible to do that? can I define an standard deviation for the geometry when I model the part or during the process in abaqus?
I don't think it is possible to define a deviation from nominal geometry while preprocessing, but why don't you study the effect of thickness by modeling the plate with min thickness and max thickness and see the differences?
Thanks shingouz
I am not sure if we model the minimum and maximum geometry can get good result as the geometry randomly changing along the part so we need a logic behind this to explain about the effect of random geometry changing.
I have heard using Ansys we are able to define the geometry deviation. Can we do the same thing in Abaqus?
Is there any other idea to model a simple part with thickness of 2 ± 0.15 mm?
Ok, did not get too much into your problem, but this ideas came into my mind, quite probable that you considered'em before:
>Do a parametric analysis (either "parametric" in abaqus or just repeat the simulation for thicknesses e=2.15,2.10,2.05 ... and do a postanalysis in your excel or so sheet.
>Use 3d elements instead of shell.
good luck
n3l3
I would assume a linear change in thickness from 1 known point to the next then throw a factor of safety on it. You could also drive the thicknesses with Python or Isight and basically do a monte carlo simulation on thicknesses. I hope this helps.
Rob Stupplebeen
