phatdats
- Dec 3, 2002
- 1
ok, i am not an EE, but a friend refered me to this page, telling me if anyone can help, you guys could....
i have some audio gear that runs off of SLA (lead acid) batteries. one unit needs 6 volts, and draws .62amps and turns off at 5.25v
the other piece needs 12V and draws 1.2amps and shuts down at 10.4volts
carrying around a 6v and a 12v sla is beginning to hurt my back. there is a company called eco-charge ( that has introduced an SLA (the EC90) that gives off 12volts and 6volts on different connectors.
I know that this is done with a voltage regulator circut. and i want to try and build my own (i am sure at a fraction of what they charge)
here are my requirements:
1. i have either 7.2ah or 10ah 12v cells. i need to run both peices for 3.5 hours (with a total draw of 1.8ah, the 7.2 battery will just work, but will a volatge regulating circut either draw some power or make this system run in-efficiently?)
2. i also need to be concerned about heat. is this gonna reduce my runtime?
i am pretty good with simple circuts, and can assemble radio shack boards and parts all day long. can someone help me with the specifics??
thanks a bunch!
steve
thanks a bunch!
steve
