Plotting multiple drawings?
Janz99
8
Hey guys, I'm new to Creo so this may be a dumb questions. Is there a way to plot multiple drawings side by side? I print quite a few A size drawings, and it seems like such a waste having 12-18" worth of extra paper to cut off when I plot a single drawing at a time.
If there is, any suggestions on where to find the information in order to set this up?
Ryan
There is no way unless all of the sheets are in the same file.
One company I used to work for had an Oce plotter that we programmed to stack multiple A and B size drawings submitted and not plot until the plotter could fill the paper width. It was nice....until you needed that 1 plot now.
Ben Loosli
If you have Windchill or some other PDM system, there may be some solutions from add-on products that will batch print files.
These are some companies that have automation tools written for Windchill/Creo.
Ben Loosli
Why not send A size to a laser printer?
is it possible to post several sheets of a drawing to a plotter (or pdf) at once? currently we print to pdf each one of them and then plot, but it's time consuming.
Some plotters have a setting on how long they will wait for another job to come along before they start to print so they can nest them. If yours can do that you could use pro/batch to send a bunch of plots in rapid succession. With the proper setup the plotter should be able to nest them and cut down on paper usage. But seriously, why are you sending A size plots to a large format plotter? It has to cost several times more per page than an office laser printer. Our large format plotter sits unused 99% of the time, everyone uses the laser printer.
