Im a new user of SE with previous experience from SW, Catia and ProE so I have a pretty clear idea of how i think things should work.
We are currentlu using the section view command in the drawing module of SE which works fine for the most of the time but I'm missing the clear connection to the 3D modell (ex ProE). The real issue I have is that I'm not able to show sketches drawn in the same plane as the cutting plane on the section view of the drawing.
Then i realised the solution for both these problem was to use the PMI section view, which I thoght worked great.
The only concern I'm having right now is to be able to show the cutting plane with arrows on the view from which I am projecting my section view from and to get a callout with the name of the section.
So my qustions are:
How can I show the cutting plane with arrows on the view I'm projection my section view from?
And how can I callout the name of the view, ex A-A, ?
Thanks in advance
regards
Anders
So my qustions are:
Thanks in advance
regards
Anders
