SDETERS
Agricultural
- May 1, 2008
- 1,292
We are having a small issue with a slot in a casting. The slot is a tertiary datum. The center of the slot is within the print. The issue is that the slot is rotated 1.5 degrees about the center of the slot. We want the tight location of the center slot which we have, we are also ok with the slot to rotate to a certain degree. What would be the best way to control the slot so we would allow it to rotate and keep the tight location of the slot?
