StructuralJoe
- Jun 12, 2007
- 43
I've got a high-rise concrete structure with post-tensioned barrier cables. The cables produce almost 8kips "pre-jacking force" and almost 6kips "final effective force". These forces vary and in some cases produce torsion in additional to lateral loads on my columns. I reviewed ACI-318 11.5.1c and in most cases the barrier cables are less than the Threshold Torsion and therefore it can be disregarded. But there appears to be a few location that may be a problem. Does anyone have a design example for reference, I have checked all of the texts I can find and I haven't found one yet? I can't find any examples of concrete columns with axial, shear and torsion at the same time. I have checked shear and it appears all of the columns will have less shear than Vc, if this is the case are additional stirrups required?
Thanks in advance
Thanks in advance
