I am modeling some prefab wood trusses for a client to determine if there is sufficient capacity to install solar panels on the roof. I am comfortable modeling the trusses and all their members. But these, like most prefab wood trusses have the toothed, pressed metal connector plates at all connections/intersections. Is it relatively reasonable (safe) to presume that these plates will develop the full strength of the truss members (2x4s)? IE that the capacity of the connections will match that of the members framing in?
