Engweld23
- Sep 21, 2023
- 4
Good morning,
I am working on verifying a pressure relief system for NG cylinders with a Spring loaded safety device set to 5000 psi. I may be over thinking this but the jist of the problem I am having is that the piping leading to the safety valve is of 3 different sizes.
.358" ID for an equivalent of 1.5 feet off of 1 cylinder to a manifold that is .815" ID for equivalent of 10.5 feet to a reducing elbow that is .614" ID for an equivalent of 5.5 feet.
I am having trouble understanding the effects of the different piping size and what it would essentially do to the pressure drop from the cylinder to the safety device. My thought is to determine the combined volume, pressure drop and temperature of the inlet gas of the 3 smaller ID tubes. Use that as the starting pressure and temp for the manifold tube and calculate the pressure drop of that tube to the next reduction, and continue to the safety valve.
I attached a simple diagram of how the gas is traveling.
