AgeOfEmpire
Materials
Hi Friends,
Could you give some information about this problem. I work on polymer processing and I have a simple test system. This system consist of heated reservoir and a piston. Polymer is filled in reservoir and heated when is melted. then polymer flows through small hole. In this system, pressure value is read a constant point in the reservoir. My problem is that pressure value is continuously drop at this point. I know that pressure should drop in reservoir but I dont understand why pressure value is different at the constant point using a constant piston speed.
If you give suggestion I will be pleased.
