Pressure Switch
Mechh007
41
Pressure tank supplier said that they cant provide pressure switch on tank.Our pressure switch limit is 5-7 bar. Can we fix the pressure switch on the inlet line which is going to pressure tank from pump discharge. Will it work out? PLease advice
It should if the line is short and the pressure in the tank varies with the pump's discharge pressure.
Line is very short ..maximum 1-2 meter length.
And the tank? Isolated by any check valve or is the pressure inside the same as the pump's discharge pressure?
