I have been looking for literature about the different possibilities of pressurisation of a district heat system, but alas I couldn't find anything proper. We are currently working with a buffer vessel on height, that takes care of the required static pressure in the system. This static pressure is needed to prevent the water from cooking. Temperatures are 105 until 135 degrees Celcius.
This system seems rather basic and requires a construction for the buffer vessel.
I would rather think of a pressurized vessel on ground level with a gas cushion inside, that is being kept under pressure by the gas, the supply of water by a centrifugal pump and a by-pass line in order to bypass excess water ( due to excess pressure in the system to the storage vessel.
If such a system would be feasible or is already applied I would like to know how to size the pump, the pressurized vessel, the gas cushion and the by pass valve. Especially I am interested how solution of the gas in the cushion into the proces water can be prevented.
Any help is welcome !
Yobbo
Yobbo
