Primary datum as a sphere?
theedudenator
27
0
0
Imagine the a tie rod end.
The sphere component has a shaft protrusion.
For functionality in the assembly, the sphere is the primary datum.
If I called out the diameter of the sphere as the datum would be it be a center point? Or a set of perpendicular planes?
Specifying a sphere as a Datum Feature of Size gives you a point in the center (vs the axis of a cylindrical feature of size), which has three mutually perpendicular planes centered at that point (there are two mutually perpendicular planes associated with the axis of a cylindrical feature of size). The planes are the datum planes from which measurements are taken.
Jim Sykes, P.Eng, GDTP-S
Profile Services
CAD-Documentation-GD&T-Product Development
But this center point of the sphere defines how the remaining geometry is created.
I understand it is not a plane, but it is the most important location for assembly reasons.
