Proposals to design a 50m cantilever transfer slab 1
Sujitha Menon
14
Good day
This is for a project in Dubai where in I have a 50m cantilver edge at the corner of the building starting from 2nd floor and the building projects out to carry 10 floors of hospital above . what will be the best proposal to design this area.The General internal floor slabs are flat slab with column drops.As cantilver support columns are spaced at 10m apart can I propose a deep 50m cantilver steel truss at every 10m span .with a back span for the span.How do I curb the huge moments incurred in the supports.Is there any option other than steel.Great if you can send me any reports you have in hand .Yes it is a 50m cantilver transfer slab--
We're going to need some sketches. Your framing arrangement is extremely hard to follow with only a worded description.
A plan view showing column locations and a section view would probably allow some of the extremely bright people here give you some real insight.
To start, a 50m cantilever seems extreme. Are you sure about your units and terminology?
The scale seems all wrong. The “50m” dimension is nowhere near 5 times the “10m” dimension.
The Sketch attached is arbitrary and not to scale. Just a diagrammatic representation of the proposal requested
The words "50m & cantilever & slab" are not words you expect to find together. Hence the continue disbelief express.
If you do want a cantilever without dropping a column to ground then then you likely want to engage many floors above to allow the slabs form a deep beam that is numerous stories high.
there are projects which I found for 66m but with 2 to 3 floors above with vierendeel trusses of 3 floor height.
I suspect that you have to use the outside walls and cantilever it the 7m distance from the interior columns to the outside wall. It's a huge cantilever and I don't know if it can be done... but, maybe a solution similar to what I've proposed.
Put a column or two in starts to solve all your issues.....
50m cantilever sounds pretty ridiculous to support a high importance structure like a hospital. I'm curious what are the proportions of the cantilevering truss, how deep, how much back-span, & how much does it deflect.
Concrete might work. Several storeys deep cantilevered beam?
Sujitha Menon, will you please post a scaled sketch showing the full plan with columns and perimeter of slab? I could not visualize the plan..
You’re not going to get a response on how to design the world’s craziest building from us strangers on the internet.
Hospital floor vibrations are usually critical for their very sensitive machinery. I think the client needs to reconsider building a 10 storey hospital over 50m of fresh air...
Putting my crazy hat on, if I were to do it, I’d be looking at at least 10m deep trusses (3 storey heights minimum) as a starting point. You have all sorts of vibration, seismic and redundancy issues to consider though. This just doesn’t seem realistic to me.
I agree with the others, I don't think this is reasonable. especially with only 20m of backspan. The uplift forces on that back end will be enormous. How are you planning on dealing with that?
Fun. I've read of theoretical proposals recently to reboot the practice of using high-rise exterior cladding for load bearing and lateral resistance. Basically, undoing the curtain wall concept. Your thing might be accomplished in such a way. It's essentially another version of the multi-story, vierendeel truss concept that you mentioned. Ductility might be a challenge if you're in a high seismic environment. Based on the 7m dimension shown in your sketch, I suspect that this isn't quite as bad as the 50m makes it sound when drawn to scale.
Yeah, minus the gargantuan strongbox in the middle and done as cladding rather that CIP. Not that CIP wouldn't be an option if were economically feasible.
In a similar vein, I suppose that diagrid ought to be considered.
Hospital programming tends to not like interior walls so options with that might be limited.
Easy... rock anchors...[bigsmile]
