tholz
Computer
- May 7, 2015
- 9
Folks,
I am working with my building management to resolve a recent issue with the building rooftop water tank refill pipe transmitting a very audible humming noise to an apartment in the building. The pump is located in the basement and tank feed pipes run directly under the 1st floor apartment and make a 90deg turn up a riser shaft located adjacent to the apartment. The pump was recently changed out to a higher Kwh pump because of the NYC mandated installation of a backflow preventer. Prior to the new pump, no hum was detected. Between the pump and 2nd pipe hanger, is a Flex-Hose NND double sphere flex connector. The pump is mounted on a steel base which sits on 4 vibration isolator pads and is bolted to a sizable cement foundation, which is part of the basement floor. My question is: Is it appropriate to have the pump sit on vibration isolation padding, if we really don't care about any vibration transmitted to the foundation and ONLY care about minimizing vibrations transmitted to the outflow piping? Seems to me that we would be significantly increasing the effective mass of the pump if it where directly and rigidly affixed to the foundation, and thus reducing the vibration into the piping.
I've attached a pic of the piping and pump mount/foundation
thanks in advance for your time and thoughts on this.
Tom
Tom
