MIANCH
Chemical
- Aug 8, 2002
- 162
Hi All,
I hope this thread will be very interested for some fellow members.
Pump is designed for following conditions.
Inlet temperature 695F
SP,GR at 60 F : 0.95 and at inlet temp: 0.715
Viscosity 0.31 CKS @ 695F
Capacity at inlet temp Normal Design 115 GPM
Capacity at inlet temp: max Design 126
Design inlet pressure is 31 psig
Discharge pressure is 128 psig.
Pump is being operated with following conditions
SP.GR at 60F: 0.59 and at inlet temp:0.477
Viscosity at 100 F 0.17 CKS
capacity at inlet Temp , normal Design 45 GPM
Capacity at inlet Temp, max Design 50 GPM
inlet pressure is killed by installing a level control.
Discharge pressure is recorded more than 150 psig.
22 years are in service and pump seal damaged more than 30 time, pump impeller and pump casing scored heavy rubbing. one time complete impeller and casing also changed. Can someone explain what is wrong with this pump or fluid handling ( I mean service of fluid)
