Pump Selection
WissamH
27
Dear All,
I need to pump 21 L/s at 105 m of head into a water network. The pump I plan to purchase is going to be from KSB. Can you please help select a suitable pump based on the design values I mentioned?
Kind regards,
Did you mean to write his as an email to KSB?
Be aware the pump needs to know differential pressure so you need to fill in a data sheet and send it to KSB.
You also need to tell them things like electrical supply etc.
Or do some homework and at least narrow it down a bit.
Dear LittleInch,
I did not mean to write an email. The analysis I did revealed that I will need a pump that can supply a flow rate of Q = 21 liters/sec at a pressure head H = 105 m. Now I need to select a pump that can give me the required conditions mentioned. I plan to select a pump from KSB. However, I don't have enough experience to do so and I don't know the right steps for selecting the appropriate pump. I assume that the starting point would be looking at the characteristics curve of the pump. I would appreciate any help explaining the right steps.
shvet, thak you so much for your kind response. I will take a look and let you know how it goes.
pierreick, thank you so much. I will take a look.
But take note of the issue about differential head.
Pumps don't deliver a set head, they deliver the difference between what the inlet pressure / head is and the outlet head/pressure.
You are better off talking to a local technical sales rep at KSB, but they will need or tell you to provide certain minimum information. Just quoting one duty point (flow at a certain discharge head) isn't enough.
OP,
pierrreick had given good direction with the KSB Brochure.
Start with Fig 17 and drill down to get the characteristics curve for the specific pump.
GDD
Canada
Pierreick and GD2, thank you so much for your support.
Dear shvet, I used the KSB Easy Select tool using the link you provided. However, when I entered my required Q = 75.6 m3/hr and H = 105 m, the tool didn't select any of the products for me. I looked at the performance curves available in the catalog, I could not find any of the pumps with a curve that matches my operating values. I am not sure what the reason is or if I am not using the tool properly.
As a follow-up to my previous post, the pump is supposed to be installed in a pumping station and transport water for water supply.
Is 105 m the TDH, difference between discharche and suction head?
Pierre
Pierreick, The information in brackets (Q = 75.6 m3/hr, H = 105 m) is my system operating point.
If TDH is 105 m then the pump 80-250 should do the Job! Fig 17 Booklet.
Get confirmation with the vendor.
Pierre
Wissam,
You're not listening to me or Pierreick.
You need to know DIFFERENTIAL HEAD, not what head you want at the discharge.
The curves will show the min and max pump curves (min and max impellor size) which then get amended to match your required duty. So as long as your required duty is somewhere between min and max you're good.
Dear Pierreik and LittleInch, apologies for my poor explanation. Yes, the 105 m is the TDH. Pierreik, which booklet you are referring to? I would appreciate it if you can provide a link.
The handbook from KSB, my post on June 18th, Fig 17 page 27.
Pierre
