aniiben
- May 9, 2017
- 158
Q1:
If in fig 4-24, the size of the tolerance zone of datum feature A is changed from zero at MMC to 0.5 RFS (for example), would the new scheme make sense ? I am asking from the fact that now datum feature A is modified at MMC in the position callout for the 8mm hole and RFS for its own positional tolerance. What I am trying to ask is if there is any issue for such a combination where a feature is called at RFS (datum feature A) but in another FCF is called at MMC?
Q2:
Fig 4-42: What is the significance of the tertiary datum feature C in the FRTZF? Otherwise stated, what degrees of freedom C in the lower segment would stop? Would the meaning of the callout be changed if C (again tertiary) is removed?
Q3:
Fig 4-45: If a basic dimension is added from datum B to the apex of the cone, can the datum feature B be modified at MMB in the positional callout for the hole? In other words, I am trying to establish a mutual location relationship to the primary datum feature A and then modify the planar surface B at MMB? Would this approach be valid?
Q4:
The paragraph 4.22 states: ".....(b) the degree(s) of freedom to be constrained by each datum feature referenced in the feature control frame shall be explicitly stated by placing the designated degree of freedom to be constrained in lowercase
letter(s) [X, Y, Z, u, v, or w] in brackets following each datum feature reference and any applicable modifier(s)."
Why the text specifies that the degrees of freedom shall be shown in the lowercase letters, but actually shown as a CAPITAL letters [X, Y, Z]? Is it just a mistake? As far as I understand the axes shall be specified in the CAPITAL letters and not the degrees of freedom. The underlined text is talking about the degrees of freedom -translation and rotation --, correct?
Q2:
Q3:
Q4:
