"Break sharp edges" note 4
mathlete7
Aerospace
Sep 13, 2008
52
I have a pretty simple question - I know that its common to call out "break sharp edges" on machined parts. I'm curious, what tool do they generally use to do this?
Or for instance, on a machined aluminum I-beam, what would be the most common way to remove the sharp edges from the flanges? Would you generally just machine a chamfer along the length of the flange? Or would you just run some tool along the length of the flange to break the sharp edge?
Thanks much...
I can assure you of one thing, if you do not put that note on, or have it in the border of your drawing, a large number of contracting companies will leave the edges like razor blades.
Guess how I know?
B.E.
I'm guessing because you serve the same role at your current employer that I did at my last one.
Human sharp edge detector.
Looks great when you're doing a fit check with the customer etc around and you slice your finger open on the part.
KENAT,
Have you reminded yourself of faq731-376 recently, or taken a look at posting policies: What is Engineering anyway: faq1088-1484
You need to spell out on the drawing what you want. In GE's mfg training school they trained compliance with the drawing. When a craftsman with a finer bent provided more than the dwg reqd, the supervisor would roughen the work with a file to meet the drawing. A specified 125 finish should be provided with the appropriate process. A 32 finish is not reqd and wasteful of time and process.
