aldumoul
- May 24, 2011
- 64
Anyone know of a program that calculates radial load? It is important in order for me to figure bearing life and shaft bending moments (we’re a spindle manufacturer). In my research, I have found this calc to be quite involved (merchants circle). Using a calc within Kennametal’s website, it computed a tangential force of 45 lbs, if that helps.
Tool is carbide, 2 flute, 3/8 dia. Workpiece material is aluminum.. 130 brinel, 47.9k psi ultimate strength. Process: 1000 SFM, 10,186 RPM, width of cut: .18. .00413 ipt (chip load). It is a mill/drill application… drill thru 3/8 material and interpolate the hole.
