Hi all,
I am struggling with PI controller to control a curretn controller.The control is in discrete time.
Basically, i have a set-up with an inverter and LCL filter.
The idea is to control, using dSPACE, the current in d and q axis measured in the output of the LCL filter.
What I'm currently doing is to use a model of LCL filter to tune my PI regulator in Simulink.The reference current is a step.
The model of LCL filter is good, there is no problem.
My simulation model is also right, I checked with an other sample of LCL parameters.
But with my set-up of LCL filter, I cannt reduce the resulted overshoot .
I don't know if you get my point...
Basically, I need to know why in certain systems we cannot reduce the overshoot, is it because of a wrong compensation of poles?...
