I have case about repair pressure Vessel in our factory. Our vessel have area of shell have thickness corroded and the thickness less than minimum design thickness. Area of corroded area just 36 cm2 (3.9 x 9 cm) that is a small area than whole of shell body, to reduce the cost, we want to change that’s area only. I want to ask you, is not possible or not? What is that role or anything in ASME that arrange about it? If ASME is not recommended, what is reason?
I will be appreciated for your assistance.
Thank you
Thank you
