Retrieving a saved template 2013
metman
Materials
Feb 18, 2002
1,187
This SW2013x64 Edition SP0
Under Options/Document Properties, I chose my preferred settings for units and visual dimension scheme. Then I saved as part.prtdot (template).
How do I retrieve the template to open it? Where is it actually stored?
I have not closed the document so I tried a Save As. It gives a path of: << Local Disk (C:)> Program Data> SolidWorks> SoldWorks 2013> Templates.
If I try to open it, there is NO Program Data file under Local Disk (C:)
Design for RELIABILITY, manufacturability, and maintainability
Have you set your file paths for your templates, in the System Options\File locations? I use a special path for all my custom templates, I don't want to have them confused with the standard SW templates.
Scott Baugh, CSWP [pc2]
Gryphon Environmental
"If it's not broke, Don't fix it!"
faq731-376
