monkeysolder
At my wits end here. I must be missing something incredibly basic. Thanks in advance.
I have wired up a simple non-inverting opamp circuit to a LM324A. I have a 10k potentiometer connected across the inverting input and output of the opamp, and a 2k resistor between the inverting input and ground.
Next I have powered it with +9v and ground.
With only the two resistors and power connected, the output is pegged high (7.8V) no matter what I change the potentiometer value to (verified with a multimeter). What could be causing this?
When I feed it an input signal, nothing happens because it is pegged.
spec sheet:
spec sheet:
