jdgengineer
- Dec 1, 2011
- 748
We have a project that will have 1 1/2" rigid insulation installed above the 5/8" structural roof sheathing. An additional layer of 1/2" plywood is proposed above the rigid insulation for attachment of asphalt shingles. All wood construction.
How is the upper layer of plywood typically attached? Would you put in 2x flat sleepers in the rigid insulation layer to attach the upper plywood to or would it be more common to use long nails (or preferably screws) for attachment of the upper layer of sheathing directly into the roof rafters below? We are in an area with no snow load and moderate wind loads (110 mph). I'm assuming the only real concern is wind uplift on the upper sheathing and we will consider the lower sheathing layer to be our structural diaphragm.
