ring stiffeners on flat head & axial stiffeners on cone
Jagmtr
23
0
0
IN
Hello everyone.
I have cone with flat head closure. I need to place ring stiffener on flat head & axial stiffeners on cone section for external pressure. I am attaching figures for better understanding.
I am not getting any clause for such stiffeners in ASME section viii div 1. please suggest me is there in any clause?
with best regards,
 https://files.engineering.com/getfile.aspx?folder=f628f61d-ddac-4951-a555-54ae369e5af6&file=Capture13.PNG
Jagmtr, no rules under Div 1 so far as I know to address this design. You will need to use "other means" :)
Mike
Axial stiffeners offer nothing in terms of preventing buckling of a shell or a cone. There is a reason they are not shown in ASME VIII-1.
Thanks guys for your kind response.
I can consider circumferential stiffeners for cone which design is possible as per code.
Can you suggest me any analytical method for flat head stiffeners design?
Hi guys
I am using PVelite software for my design.
when i am considering cone to cylinder shell junction as a line of support, my cone thickness is increasing very much. I understand that it is only due to moment of inertia requirement of junction. It is only our choice to choose junction as a Line of support & not mandatory. Am i correct?
when i applying circumferential stiffeners on my cone, cone thickness is not reducing. I am not getting why it is so?
Jagmtr, I understand standard UL-142 has design guides for stiffeners \on flat heads, I can't confirm. It looks to be quite expensive. One of the books by Blodgett may have something as well.
Based on the sketches you provided I have doubts that your cone design meets the scope of Sec VIII, Div 1. I refer to the half-apex angle, the joint details between the cone-cyl and cone-head junctions. See UG-32-(f), UG-36(e), Apx 1-5(g), UW-3(b), Table UW-12, Type (8).
Mike
