SA-105 Nozzle
ENG2194
45
Is there any part of code that says i cant use a hollow cylindrical SA-105 forging for nozzles as long as it meets the thickness requirements? Can it be assumed from UG-6?
ENG2194, SA-105 is commonly used for forged nozzle bodies, long weld neck flanges, and various "heavy barrels" such as HB necks and so forth.
Mike
I believe All your examples meet an an ASME 16.# standard that is explicitly allowed by Sec. VIII in UG-44. My question is more so using a hollow SA-105 cylinder when its not included in an ASME 16.# standard.
Yes, that is what I meant by forged nozzle bodies, a custom forging used with a weld neck flange, or without for a butt weld connection.
Not recommending this source :)
Put different, which sections of the Code have you checked so far that gave you the impression you cant use SA-105 forgings for nozzles ? Sure we can help, but rather than doing your homework: reading the code from time to time instead of asking experts/experienced engineers can provide a very useful learning curve[smarty]
Ive read through good portions of it. Ive gone to all the sections i feel are applicable. I believe its not an issue. Other colleges are giving me a hard time with is. Just checking if there was a more definite answer some
place to put them at ease.
