same callout for same components automatically
Forzindi
12
hello all,
can anyone help me to give same callout for same repetitive called components (means if I have two quantity of same component than it should have same callout). I know we can do manually but any trick to do that automatically.
it will be great help. thanks
NX 11.0.2.7
Right Click Parts List
Settings
Parts List
Reference Symbol Text (Drop Down, Select)
This will give you the what you want but it will have a "REF" Tag along side your callout in the balloon.
Dave
Automotive Tooling / Aircraft Tooling / Ground Support Structures
NX9, Win 7 Pro SP1
thanks @ 3dr.
actually I am looking for this in assembly model and team center structure manager. please throw some light on that.
When ever you add a component at your assembly, the item #, callout, sequence # will increase by 10. So if you add 10 parts that are all the same, your item#'s will be 10,20,30.... which is terrible in some ways, other ways it could be good. I wish there were more settings on how to control how these item#'s are assigned in teamcenter.
I don't use Teamcenter so I can't help you there.
Dave
NX9, Win 7 Pro SP1
can you rephrase the original question ?
Is it that , if the "detail_A" appears in any assembly, it should then always have
callout "347" , because Jim and Pete in the workshop then knows what part it is ? ( Yes, i have had this discussion with a customer.)
or is the question that if "detail_B" appears in "n" places in the same assembly, all "n" occurrences should have a balloon with the same number ? ( and that number is/can be different between assemblies)
Or is it that only one of the "n" "detail_B" should have a balloon, but all "n" should be on one line in the NX BOM ?
Tomas
