Search/Get "Text" value inside Definition property of 3D Annotation Set
Thosnow
Aerospace
Feb 23, 2017
68
Hello All,
I am able to select "ENG" property in 1st picture below as per my short macro below. However, I do not know how to search and get the text (i.e. PLATE) in the definition of "ENG" as seen in second picture below.
Please help me out.
Picture 1:
DEFINITION OF "ENG" property
Picture 2:
My short macro
Sub SEARCH_PLATE_IN_NOTES()
Dim oSel As SELECTION
Set oSel = CATIA.ActiveDocument.SELECTION
oSel.Clear
oSel.Search ("Name = ENG*, All")
MsgBox "HERE" '// Indicates macro got to this point
End Sub '//// End of this Subroutine
Thank you in advance
if your search return only annotation object, you an get the text with:
Code:
CATIA.ActiveDocument.Selection.Item([i]x[/i]).Value.Text.Text
Eric N.
Thanks itsmyjob....but how could I search for specific word "PLATE" and extract it of text string?
the line of code passes the text value of the selected annotation to the variable myAnnotationText
Code:
myAnnotationText = CATIA.ActiveDocument.Selection.Item(1).Value.Text.Text
Eric N.
if you need the Text object of the Annotation then use only
Code:
dim myText as Text
set myText = CATIA.ActiveDocument.Selection.Item(1).Value.Text
if you need the string then use
Code:
myTextasString = CATIA.ActiveDocument.Selection.Item(1).Value.Text.Text
Eric N.
thanks...I will try and see if it works.
HI itsmyjob...
I now get to the text string display on the monitor as per your code above: myTextasString = CATIA.ActiveDocument.Selection.Item(1).Value.Text.Text
But how can I search/obtain above text stream for word "PLATE" or any other word (as strings) in the text stream accessed above?
Is there any CATIA command or macro method to achieve this?
this is basic(not CATIA) VBA string manipulation, google it
Eric N.
