Shaft alignment sensor mounting
204
Is it possible to mount the shaft alignment sensor on the flexible hub (but in locked position) ?Will it affect the readings?
Is it possible to mount the shaft alignment sensor on the taper shaft ?Will it affect the readings?
This discussion should move to a Millwright discussion board. An engineering degree is not necessary for correctly mounting a laser alignment tool or for turning the shaft to take measurements.
Walt
