Shelf Angle for Round Concrete Column 1
Guest
Hey everyone,
I need to support a beam on a shelf angle that attaches to an existing round (1'-4" dia) concrete column. I'm looking for suggestions on how you guys usually attach a shelf angle to a round concrete column.
I don't like the idea of using a radius bent shelf angle because the anchors will end up too close together to get sufficent development. I assume there are some "clamp" type supports out there?? Anybody have a manufacturer of them?? Other ideas??
All comments appreciated.
Pouring,
If the column has not been poured yet, you could embedded a steel plate with strap anchors and shear key (if necessary.)
The shelf angle or clip angles could be bolted or welded to the plate, and bolted to the beam.
If the column is existing, anchor bolts drilled and epoxy into the column would be needed to connect the shelf angle or connection plates to the column.
I have seen steel clamps around square and round concrete poles used in power lines. Maybe you could check with power transmission line hardware suppliers.
Pouring,
In the past we have used channels, oriented vertically, with their legs turned toward the column, to anchor other structural items. The channel's legs make it self-centering on the round column section, and the channel may be made as wide and as long as necessary to provide for adequate anchoring. This is especially handy for attaching girts to existing concrete columns and piers to allow retrofitting siding to a structure.
David
Thanks for the responses. They were very helpful.
