Simplify an Array Operation 1
Sparweb
Aerospace
May 21, 2003
5,156
I'm looking for a simple array operator (or combination of operators) that will do the same thing that I currently only can do by explicitly computing the value for every element.
Somehow, I can't find an array operator that will select the values in two arrays, subtract them, and then store them in a resulting array.
To picture what I'm doing, think of a box with several compartments. The air pressure in each compartment is different. The difference in air pressure on each of the walls determines the force on each wall.
Sounds like a simple problem, but I can't find the operator that will solve this when I store the pressures in an array.
An example of what I am trying to do is attached below.
I also included in my attachment a "forced" answer where I manually calculate the answer and show the correct result. It shouldn't be that hard.
STF
 http://files.engineering.com/getfile.aspx?folder=23e72b6d-126e-40ef-b25c-a60ad722c80d&file=matrix_math_STF.xmcd
Like this?
TTFN (ta ta for now)
Y'know, a little voice was saying it was going to be obvious when I saw the answer.
Consider my forehead to be firmly slapped!
STF
