Sketch Offset Spline 2
robperly
Industrial
May 23, 2002
9
Help...
Is there any way to offset a spline in sketch mode (Solidworks 2003 SP1) or do I have to re-sketch the projected outline of my model with arcs and lines?
OR -
Can I convert splines to something else that can be offset
Any help appreciated,
Rob
Currently SW does not support offset splines.
loooong workaround
•Make an extruded surface from your spline sketch
•Offset the extruded surface as needed
•Use edge of offset surface in a new sketch
IIRC, you can open a NEW sketch, select the spline and then do an offset.
Yes!!!!!!!! New sketch offset works - Arlin you are the man!! You just saved me about2 hours of sketching!!!!
Mucho Gracias
Rob
