dik
- Apr 13, 2001
- 25,983
I have a small, 6' high cantilevered platform constructed from HSS. It is for a single person and will be designed for a loading of 300lbs. It is cantilevered from the HSS post attachment at the base to concrete, secured using Hilti chemical anchors. The loads are likely capable of being resisted by Tapcon (I'm not too keen on).
In past, when I've designed these, I usually consider a lateral loading of 15% of the vertical loading at the platform level. Is there a code or standard that recommends something else, that anyone is aware of?
