Soft starter cable sizing thump rule 2
Alms88
27
What is the simple thump rule to calculate cable size for DOL starter and soft starters
Motor is 315Kw, 568 FLA, LRa= 3000amps
Soft starter will be voltage ramp from 65% to 100%
10 seconds
125% of motor full load running current.
Or the appropriate table in the NEC where the ampacity is dictated by motor HP.
Bill
"Why not the best?"
Jimmy Carter
There is no change in cable sizing rules based on using a soft starter or any other form of reduced voltage start method.
